RCU Forums - View Single Post - Vectorflight Edge 540 build
Thread
03-01-2005 | 02:04 PM
813
Sturtz
My Feedback: (
20
Sep 2004
1,537
El Reno, OK
RE: Vectorflight Edge 540 build
Ok,, I used epoxy to set the wing joiners. Then after it cured I found a bit too much gap so I sanded it down till I got a super tight fit.
I had to go to a 5x16 bolt and wingnut to make it work. But that's not a big deal since I'm using a 91FX and I can spare a bit more weight.
On the rear area of the wing I used a couple of collet type prop adaptors from brushless motors for my lockdowns. I removed the collars and inserted them backward into the holes. Epoxied them in and used thin paper washers with foam safe CA to finish .
The prop nuts have holes through them so a small screwdriver or nail can be used to tighten them up at the field. They are holding very well so far. And since they are aluminum they weigh practically nothing.
Reply
Like
Sturtz
View Public Profile
Send a private message to Sturtz
Visit Sturtz's homepage!
Find More Posts by Sturtz
View iTrader Profile
