ORIGINAL: rcoreno
hello
can you explain to me what you meant when you said
you used
l8 mah and 20 mah to adjust the rx and tx discharge rates
thank you
ralph
I asked the same ?? heres the answer from a previous post:
The 18 and 20 mAh really has no relevance to the procedure. The Accu-Cycle is in discharge mode when you are doing the calibration. 18 and 20 mAh is how much the batteries partially discharged while I did the calibration, expressed in mAh. Assuming a constant discharge rate of 250 mA you can also express this in time:
18 mAh / 250 mA = 0.072 hours = 4 minutes 19 seconds to calibrate RX
20 mAh / 250 mA = 0.08 hours = 4 minutes 48 seconds to calibrate the TX
Again, this has no relevance to the procedure. Everyone will take a different amount of time to calibrate their charger.
Hope this helps,
Juice
