RCU Forums - View Single Post - Elevator + Tail wobble
Old 03-01-2005 | 05:22 PM
Redback's Avatar
Redback
Default RE: Elevator + Tail wobble
Phil,
Assuming that there is not a design flaw in this model (I'm not familiar with it), and assuming that you have put it together correctly it should not be necessary to add extra bracing.
Its hard to make a call without seeing just how much the tail surfaces are vibrating. If you are able to get out on Saturday someone will give the plane a check over. If it checks out and there's an instructor around you could be flying
Terry
