Pizzaz Questions?
I picked up My Pizzaz Today! I am very excited! The covering was perfect, and I am really impressed with how light and sturdy it is for an ARF. Here is my plan for setup:
Saito .72
APC 13 x 6
2-HS-422 alerons
2-HS-85MG elevator halves mounted in rear
1-HS-605 Pull-Pull rudder
1-HS-81 Throttle
4040 Hardware
Dubro Hinges
Sullivan RST-10 FlexTank
1100mha 6V battery
Saftey switch with 6V regulator
I have a few questions:
Where is the best CG? The inst recommends 31/4 to 3 3/4 but I have read threads with it as far back as 4 3/4?
The inst only recommends high and low throws, I would like to set up high, low and 3D? what throws do you recommend?
Any other suggestions?
Thanks in advance
