RE: The TRUE cure time of epoxy...
me too zetor. Just pour out equal sized pudles and go for it. Only times I have had problems was when I had too much resin in the mix or when it was cool with high humidity.
BTW, We use 91% Alcohol you can get at Walgreens. Not the regular stuff it has too much water in it. Get the 91% , stick your finger in it and wipe a joint to make it slick as glass or to form a perfect fillet. Just be aware that if you have any nicks in your cuticle its going to burn like the dickens,,, but it sure does slick out the surface of an epoxy job if you dont overdo it. Obviously its perfect for cleanign epoxy off your hands, but once again its oging to burn in any little cut..
