RE: OS 77 SETUP
if this is your first jet i would refrain from the turbine in a first jet the f-20 is a wonderful jet but not a trainer jet i would suggest a byron mig 15, yellow a-4, byron f-16, bvm f-86 something that will "float" or has some glide to it so you can learn the transaction from not relying on the prop if it has some glide to it you can get out of trouble a little better than having your jet just fall out of the sky just like most of us you dont learn to fly for the first time with an extra 300 you start with a trainer the difference between a prop and a fan is like night and day your byron f-20 is getting hard to find and i would hate to hear if you cracked it up trying to learn with it its a beautiful aircraft hope you have many flights with it hope this helps keep em level donnie
