RCU Forums - View Single Post - 2 Stroke vs. 4 Stroke
Old 09-16-2002 | 02:08 PM
bgi
My Feedback: (7)
Default 2 Stroke vs. 4 Stroke
Published HP figures are almost always misleading because they're typically calculated from exaggerated RPMs.
While 2-strokes like to run at high RPMs, four-strokes are typically happier at lower RPMs where they have much more torque than 2-strokes.
HP = torque (ft/lbs) * RPM / 5252
So it's easy to see that the 2-strokes, while producing more horsepower than the 4-strokes, do so because although they produce less torque than the 4-strokes, they operate at much higher RPMs. On the other hand, a four-stroke with more torque swinging a larger prop will perform similarly.
Is this as clear as mud now?
