RCU Forums - View Single Post - Just got Nouva nitro , need help !
Old 03-02-2005 | 09:26 AM
gmbnj
Default RE: Just got Nouva nitro , need help !
I am using the silicone for steering. I tried the spring set up but felt the silicone was better.
The steering is reverse and the rake is in the middle. There is a dampening shock for the rake.
So, should I set the rake at its maximum ? Meaning closer to the bike or farther away ?
Do you use the side protectors, do they get in the way of tight turns ?
Thank you for you help .
