RE: Glow plug??
McCoy plugs are great,,In the right engine an OS cv-r is designed to take a short plug (McCoys are long). This will add compression to that little engne
Try an OS plug #8 or other medium to hot short plug from best results if you are running 20%, if you run 30% run a colder plug OS A-5 or similar short plug
Don't forget to retune the engine to the different plug
