RCU Forums - View Single Post - 1.20 Edge Review, the beginnings
Old 03-02-2005 | 10:45 AM
Tired Old Man
Default RE: 1.20 Edge Review, the beginnings
Fuselage Interior Views
As you can see, the type of construction is very similar, or the same as the 28% planes. This one seems to be a lot lighter in weight on a proportional scale.
The area where the gas tank will be located will have a floor of either balsa or ply for it to rest on. I haven't decided on that part yet.
Looking at the bottom of the engine mounting box and you can see a real nice touch for those that like to, need to, or want to, mount their throttle servos up front. A servo cut out on both sides of the box. That's kinda neat cuz it should cover the throttle servo location for either a 2 stroke or a 4 stroke engine. For those that want to use a small gasser, it alos provides a choke servo location if desired.
There is a lot of room for the radio gear inside the fuse, and once again a cut out has been provided for a rudder pull/pull installation.
ID:	236990   Click image for larger version
ID:	236991   Click image for larger version
ID:	236992   Click image for larger version
