Moki 1.8
i'am running a moki 1.8 in my hangar 9 edge that i can't get to run properly. i'am swinging a 20x8 master airscrew prop. the proplem is i can't get it to transition from mid range to full throttle. it just seems like it smothers out. exspecialy if you do the wall into the hover it seems that you run out of power until it falls out of the hover then the engine will pick back up. what prop are you all running on the moki 1.8? any help would be greatly apreciated. thanks
Chad
