RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 03-02-2005 | 11:33 PM
  #1307
Barry Cazier
My Feedback: (17)
Default RE: U-Can-Do 3d 46?
goldenclan, Don't worry too much about the CG on the UCD46. The factory offered an addemdum to the manual which states you can balance the plane anywhere between 4 and 6 inches from the leading edge and still fly fine. I run mine about 5 3/4" It makes it 3D a little bit better but is still ridiculously easy to land. Such a fun, fun plane. Anyways, I wouldn't bother trying to move too much stuff around. If you are in that range you are good. Has a longer CG tolerance than any plane I've seen.
Barry
