ORIGINAL: drunkenbushman
just on the right thrust, what is that, i have never herd of it before is it good or bad? will i need to mod it?
Right thrust is produced by mounting the engine so that it points a degree or two toward the right side of the aircraft. It helps to counteract the torque produced by the engine (really simple explaination). Some models also are designed with down thrust. I do not recommend you make a modification to the thrust line that is not included in your manual, or is suggested/guided by an experienced flyer. Improper thrust angles can make an airplane uncontrollable
