ORIGINAL: EL ****CANO
HEY MANS
A LOT OF YOU SAID EPSILON IS "PATTERN" ......................
I THINK NO.
EPSILON IS A SPORT OR 3D PLANE, IF YOU LOOK A REALLY PATTERN PLANE IS VERY VERY DIFFERENT, THE FUSELAGE, AILERONS.
PATTERS PLANES ARE HAVE BALLISTICS FLY, BUT EPSILON YOU CUT THE ENGINE IN A DOWN VERTICAL AND THE PLANE STOP, GET DOWN SLOWLY, BUT A "PATTERN" DON“T LOSE THE VELOCITY.
HERE AN ECLIPSE "PATTERN" END EPSILON SPORT OR 3D......
Modern Wide body pattern plane are also designed to have a lot of drag for slower down lines. The Epsilon is a .90 size version of modern pattern planes. Also, since the P-05 schedule has so many difficult maneuvers the ailerons, elevator and rudders on the latest generation of pattern planes have gotten so big that most can do a pretty good job at freestyle aerobatics and 3D. Their tail moments are just a bit too long for the tumbling maneuvers like waterfall though.
