Hey Daniel... All I can say is Practice..Practice and more practice:-)
That's about the only real thing that helped me... As I said I went thru
2 gals. of fuel within the last week.. I did stay home today:-(.. I had to
make ado with the boss since my purchase of the Yak... I'm by no
means good, Altho I can hover the UCD at will.. Still a bit of the shaky
thumbs when I get down to 5' and below... Main thing I can say is just
go with the flow, small moves.. find the "sweet spot" and when the
thumbs start to act funny try something else for the moment that you
can do better, Then get right back doing what was a little harder But
start higher becasus its eaiser, If anything because you have more
thrust to work with, And the height will remove the ground effect that
works on you brain/thumbs which is not good for the plane
