RCU Forums - View Single Post - Composite ARF Impact
Old 03-03-2005 | 11:40 PM
  #404
Eric.Henderson's Avatar
Eric.Henderson
Default RE: Impact
They are sold by [link]http://www.planesplus.com[/link] tel (630) 904-5075. (They are in Illinois BTW)
I have used the side-mounting brackets for many years. They used be RC City products and were subsequently purchased (and produced), by Planesplus after RC City went bust. PlanesPlus had them at the WRAM show also had quite a few pattern goodies including Chip's b.b. horns and clevices.
This final assembly is taking a bit longer than I thought it would but the good news is that the second one will be much faster because I am taking templates or making copies for the tricky bits.
I also picked up some really good wing bags for the Impact wings from [email protected] They are nicely padded and take the 1" wing tube in the wing-tube-pouch. My other bags either did not have a pouch or the tube was too tight a fit. Adrian is a keen pattern flyer and very helpful if you need anything. I particularly liked the slot for a business type card so that you could identify the panels for each plane exernally.
Regards,
Eric.
ORIGINAL: David Gibbs
Very nice work Eric -- I too hope the problems are licked.
BTW -- are those mounts your elevator servo is on readily available? I keep cutting up aluminium angle to make brackets -- but those you are using look neat, and I haven't seen them anywhere.
David
