RCU Forums - View Single Post - Great Neutral Point Calculator - no math needed
Old 03-04-2005 | 09:47 AM
adam_one
Default RE: Great Neutral Point Calculator - no math needed
Hi Geistware,
Your formula for NP = Tail arm * (Stab Area / (Wing Area + Stab Area)) requires that the wing and stab have the same aspect ratio and also the stab should not be operating in the disturbed air from the wing, which is not so usual.
The empirical formula that uses the tail volume ratio Vbar gives a result much closer to the reality.
