I HAVE to agree with the four stroke comments. I fly exclusively four strokes since I bought my first, and will fly nothing else, unless it's gas.
The sound, the torque, the larger props, the sound, the fuel economy, the sound, and better vertical.
In addition to the razor plane and the incident meter, here's my recommendation for tools and stuff. (By the way, a hollow core door works fine as long as it's supported well.)
Glues: 30 minute and 5 minute epoxy, with something to mix it on and with, (old plastic lids and wooden coffee stirrers, plus small plumbers' acid brushes). Thin CA. (Not "Superglue") and Medium CA. You can substitute wood glue for the CA, but it adds time to the build.
Tools: XActo knife and extra number 11 blades. (Buy a box of 100, it's cheaper and you'll use them.) Razor saw; Kona or XActo. Kona is better. Steel straight edge, 18". A ruler will work but.... Sanding blocks and various grits of sandpaper. (80, 120, 200, 400.) Screw drivers, small and medium sizes, both flat and phillips types. Pliers, needle nose and regular. (At least one pair with side cutters for wire.) A good set of Allen or hex wrenches. (IMO, Ball drivers are a bit better if you can find a good set.) A "Dremel" type rotary tool will help a lot if you can shell out the extra dollars.
A decent soldering iron, not the "gun" type, I recommend 40 watts at least. Rosin core and Silver solder, flux.
Covering tools: A sealing iron. A Trim iron will help too if you can swing both. A Heat gun made for covering. (Blow dryers don't really get hot enough.) More of those #11 blades for your XActo knife if you didn't buy the box of 100.
Check the kit contents. Most will have a list of extras you'll need to buy; like wheels, fuel tank (& size), fuel line, etc...
By the way. You should buy the engine and radio equipment when you get the plane. You'll need them to finish the plane, and in some cases, you’ll need them to get started. Buy an engine on the larger size of the recommended range.
Some type of "flight box". (A plastic tool box of appropriate size and design works well and will be cheaper than the "specific" flight boxes.) Some good ones at Lowe’s or Home Depot. A gallon of 10% fuel, a fuel pump, manual or electric and fuel line (3 feet minimum), fuel filters and fittings for the fuel can. A glow igniter with charger. Although not 'necessary', I highly recommend a 12 volt starter for the engine, because most new engines are quite hard to start with a “chicken stick”, and it’s one more headache you don’t need when beginning.
If you buy a 'self contained' glow ignitor and starter, and a manual fuel pump, you won't need to buy a separate 12 volt battery with charger, nor a "power panel" to connect everything. (And you won't have cords dangling around your prop when trying to start the engine.)
Then, get a few props of slightly different diameters and pitch (in the recommended range). The engine directions should give you a range of appropriate sizes for your engine. One or two extra glow plugs should last you through the learning process. I'd recommend OS "F" or Fox Miracle plugs for 4 strokes, OS #8 or A3 for 2 strokes.
Good luck and have fun.
Dennis-
