RE: Elevator servo location
Bluemagic, the bottom servo cutouts are for rudder servos if you are going to use pull pull then do not cut the covering, Tom is very good at giving us planes that are easy to set up so if you need extra tailweight or prefer push pull then mount your rudder servos in these locations.
