RE: add split flaps to strip aileron wing?
If the problem is actually too much speed, the split flaps described may not help very much. The approach speed is determined by the stall speed, and split flaps deflected 80-90degrees won’t reduce the stall speed significantly. Attempting to fly a steep approach with a clean configuration will in fact result in a faster approach. By adding drag you can make a much steeper approach without picking up speed, which will provide easier control on final. This may be what you need rather than a slower approach speed.
