If you need a 61 engine let me know, and tell me why I should give it to you.
Engine specs:
.61 Mutunuc engine w/muffler and 5/8" muffler spacer/extension (Tower part
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
This is an older ABC, Chinese (Taiwan ? ) made engine. The only thing it needs is a prop nut (I can't find the original [&o] ). I had the engine on a plane and swapped it out for a Thunder Tiger 61 (saved several oz in weight ) I picked the engine up last year with a bunch of stuff at a swap meet. The engine appears to be low time, has excellent compression, runs great, very good transition/idle and has the original box and some of the original instructions.
The engine is heavy. The engine and muffler weigh in at about 23 - 24 oz.
