RE: World Models 33% ultimate
smokey.....Is not possible , the space is just enough to insert the motor box side in place,then you have to insert the wing cabane base through the top of the fuselage and bolt it to the motor box side.It is very tricky this part of the assemble ,but like I said before it is the only two hard things to do.
The wheels are made of hard foam,they look pretty strong .I'm gonna give them a try and for sure they will go flat, if we leave them with the weight of the plane for a period of time.
..did I mention that they also included the tap to do the tread on the wings tube!
I live in dutchess county,I'm a member of the Mid Hudson rc in Hopewell Junction
