RE: ryobi-will not start
sboxer;
Your info is a little short. Are you hand starting it? or using a starter?. Some of the modern coils are very reluctant to produce a spark at lower rpm's. A combination of being mounted on the plane, being lower than bench height or just too cold to give it a good flip may be all that is wrong??????????????. If you are not doing so, try a starter first to get those extra rpm's.
Peter
