RE: New CA models Epsilon build (easy as pie)
Timo,
I got the ARC and had all kinds of problems with it. The wing wouldn't fit on the fuse. Way off. With the dowels in the holes and the front of the wing on the saddle, the back of the wing was almost 1/2 inch above the saddle. The belly pan was not centered on the wing, but off to the side about 5mm. The hard points in the ailerons were not in the same place. One was closer to the hinge line than the other. I wasn't very satisfied with the quality. If it flies well, all will be forgiven. If not...
