Originally posted by moses
The unit should be able to verify that programming was successful and notify the user of the results (i.e., successful or unsuccessful programming).
That is why I am a little confused about the concerns of programming a servo through an extension. I did go through the extensions when I reset my servos however with all 5 of them the end result was SUCCESS on the programmer. One would think if there was a problem communicating with the servo through an extension the end result wouldn't have been a success.
The thing that no one knows is would this servo of failed me if I hadn't reset them. It quite possibly could have been just a bad servo and if so then the programmer isn't an issue at all. Unfortunately no one can answer that question so I must go on what was changed from the last successful flight until the next eventful flight on that being the only change was a reset of the servos.
