RCU Forums - View Single Post - ryobi-will not start
Old 03-07-2005 | 11:51 AM
sboxer
Default RE: ryobi-will not start
I think the key issue is very possible. Between the time I had the engine on the test stand and then mounted on my model, I sent the flywheel out for balancing. I believe that I slipped the flywheel back over the notch on the shaft and I certainly see the piston going up and down. What else should I look for?
Thanks for giving me something to work with.
SB
