RE: Extreme Flight 87" Yak 54 - Build & Fly
Chris:
Chaulk mine up to one of the ones with a problem... I couldn't stand the suspense, so I went home at lunch to check the alignment of the wing / stab tubes... Sure enough, the wing tube is off by at least 1/2", left to right... The tip of right side of the wing tube is noticeably lower than the left... The stab tube appears to be correct though... I will email you directly with photos...
Also, congratulations on the engagement... I hope your's is a long and happy marriage...
Mark
