RCU Forums - View Single Post - Composite ARF Impact
Old 03-07-2005 | 04:37 PM
  #420
MTK
Default RE: Impact
Jim O,
I have had brand new 8411's behave similarly to what Eric Henderson described above. Very rapid and extreme oscillation at neutral, on other surfaces besides rudder, on pattern and larger planes alike. I sent them back and was told that the dead band at neutral needed to be broadened. Yet some (most?) 8411's do not display that oscillation so maybe there is something to that. As an old Radio man, you probably know better than anyone. I would really like to know what the answer is.
MattK
ORIGINAL: OhD
Eric,
Has anyone tried replacing the cables in the pull pull with carbon fiber rods as used in the elevator set-up? Seems like we don't want any thing that works like a spring in our control system. We need to get the natural frequency of the mechanical system up higher than that of the servo. I'm using two solid pushrods on the rudder of my 2.6M Extra (to two servos) and there is no sign of oscillation and there is zero slop. Just a thought. I bought 8411s for my Impact but haven't decided how I'm going to install it.
Jim O
