Fuel Proofing
Yes I've done it with a heat gun. I found that it was handy especially if you had your covering wraped around onto the firewall or even the sides pulled into the engine area. It did a fine job of sealing the bare wood and also held the covering from coming loose.
Try the heat - not too much or you'll burn the epoxy - you'll like how it flows. Also works when glassing a wing.
