High voltage or Low voltage cut off?
I can program my Jeti ESC for high or low voltage cut off. Which do I want? I'm running an AXI 2814/12 motor with a Jeti 30 amp ESC and a LI-PO pack 3S2P rated at 3000MAH. The Packs are rated at 8C. The motor runs at full thottle for about 1 minute and then shuts off. The ESC is set for High voltage shut off. should I run it at low Voltage shut off or will this ruin the pack?
Thanks for any info.
