RCU Forums - View Single Post - fuel pump or no pump, whats the diff???
Old 03-08-2005 | 02:35 AM
rcdude7
My Feedback: (264)
Default RE: fuel pump or no pump, whats the diff???
The pump engine gives you the option of mounting your fuel tank near the CG, since tank position becomes non-critical. Also the pumper will not tend to lean as the fuel supply burns down, so engine performance will be more consistant throughout the flight.
OS replacement fuel pumps cost a small fortune. Buying a regular carb and a new backplate would probably be the most inexpensive way to go.
