RCU Forums - View Single Post - Tiger 2 Wing Saddle Problem
Old 03-08-2005 | 06:22 AM
Kaos Rulz
Default RE: Tiger 2 Wing Saddle Problem
ORIGINAL: shakes268
I measured the alignment, it was fine. I then measured and marked off how much I would need to sand to allow it to drop down into the saddle. Removed the covering in that area, sanded it down and then used a covering iron to put the strip back that I removed. Looks perfect now. I just wanted to find out if there might be a better way before I did anything.
Thanks for the help!
Nope! You did the correct thing. Good flying plane BTW.
