cut-off problem
I'm flying Tensor4D + Elite 1080kv + Pheonix 10 ESC + TP 760 3S + APC 10x4.7. The escape is set for automatic end point adjustment. That means that it detects top position of throttle stick, and adjust itself accordingly. The problem is that in full throttle the ESC cuts off. I just had a crash because of that.
I'm new to electric, and want to solve the problem without the need for prop replacement (yes, I know that replacing for smaller prop will solve it, but I wish to stay with the APC 10x4.7). Would it be right to program the ESC for fixed throttle end point, and limit the end point from the transmitter in a way that it will not rich the cut-off range ?
Yaniv.
