RCU Forums - View Single Post - First build - Sig SE started
Old 03-08-2005 | 10:34 AM
  #32
h@h racing
Default RE: First build - Sig SE started
krossk
I extended the sides with parts from the kit. You took the sides of the fuse out of the lazer cut balsa sheets. This extra from the sheet is what I used to extend the sides. The front is made out of balsa sheet and formed to get the curve and two pieces laminated together and cut to size to fit between the sides. The top is one sheet from the front of the hatch to the front of the cowl. It was soaked with water and taped to fuse to form the top. I will get pictures of the bottom at lunch and post. The bottom is open for access to the engine.
ID:	240213   Click image for larger version
ID:	240214   Click image for larger version
ID:	240215   Click image for larger version
