http://members.cox.net/bdfelice/Pull-pull/pull-pull.htm
Almost at the end of this page there is a setup for a throttle pull pull using a spring. What are the advantages of this setup? I have never seen this before. It seems like it might be good if you had a less than direct path to the carb, you could turn a corn pretty easy.
