ORIGINAL: jrjohn
Here is a silly little Idea that has a decent cchance of working. ( My brain works really good in the morning. However at night I can hardly tie my shoes.)
Take a spray bottle and mist the inside of the airplane. then secure it to your workbench. Water won't hurt the covering, and if you just mist it, you shouldn't harm the glue. Using your wingtube and stab tube put an opposite twist in the fus. with a makeshift jig. ie wook clamps ect. Over twist it slightly.(just a hair) Then reshrink your covering and either use a hairdryer on low heat, or let the thing dry on it's own. make sure it remains jiged and slightly over twisted the entire time. I'd let it sit for atleast a day either way.
just thought of the jig. Get two pipes, dowels or simular. extend your wingtube and stab tube with such. then add weight to opposite sides out at the end of the dowl. an old sock with sand will hang on it just fine. adjust your weight to get the right twist.
John
NO NO NO!!! If you tri twisting the fuse in the back with the stab tube, you'll BUST THE TUBE RIGHT OUT OF THE FUSE!!! If one really wishes to give it a go, then try twisting the fuse by the VERTICAL STAB and NOT the HORIZONTAL STAB.
I, for one, will wait for my new fuse. Back in my day when I was a pretty good pilot and had 20/15 vision, I flew a 33% Pirate models Extra 260 with a twisted tail and I could easily see it veering to one side when I pulled or pushed vertical. I am a bit rusty now, but I plan on getting good again, so I would like to start off with a straight plane
I will say, however, if you have no intentions of flying and type of precision or hardcore 3D (like the Wall), then build and fly and enjoy...
