RCU Forums - View Single Post - pull pull on throttle
Old 03-08-2005 | 05:27 PM
Red B.
Default RE: pull pull on throttle
Minn Flyer wrote:
I saw that setup too, and I can't help thinking, "Why would you want to put a constant stress/Battery drain on your throttle servo?"
I have used a similar system with great success for several years. The trick is to choose the spring carefully. It should be weak enough not to cause the servo motor to operate and strong enough to close the throttle if the pulling wire is released.
/Red B.
