RE: MT2 Tuning troubles - HELP!!!
are you sure its really lean on the low side? could the low speed needle be damaged in some way and giving a false reading.... I took my old carb apart the other day and found the needle was dented at the tip, which explained the difficulty in tuning the truck.. the new carb directly from cen required very little adjusting especially the low speed...
