RE: High voltage or Low voltage cut off?
I have to question your use of full throttle at one minute. If I did that on my models, I would never see them again!
Hopefully, you were not doing this on a static ground test. On a normal ground test, use full throttle for only 5-10 seconds.
In flight, your use of full throttle should not be more than 10-15 seconds.
