RCU Forums - View Single Post - help arf covering problem
Old 03-09-2005 | 12:47 PM
dieFluggeister
Default RE: help arf covering problem
Hey Bass,
Its no problem. Depending on temperature factors during manufacturing and shipping you can expect some wrinkles. Yours seems more than some but all it usually takes is a heat gun or iron to remove them to a durm tight finish. Inspect the edges though to make sure they are not loose
If you have never had any experience with covering you may want to ask an old pro from your club to show you how. There is some technique involved but it usually consists of slowly shrinking the covering with only as much heat as needed, starting in the center of a panel and working outward, constantly keeping it moving.
The biggest problem you can run into is too much heat or staying in place too long. Film will melt.
Chances are in 15 minutes you can have a great looking model.
