RCU Forums - View Single Post - Which 4-stroke to purchase?
Old 01-02-2002 | 01:58 AM
  #37
GUNSHIPGUNNER
Default Re: Horizon says to use 30% ?
Originally posted by IronZ
Where did you see this recommendation to use 30% heli fuel in all Saitos? I have often thought of doing this with my .72 but was advised against it because it will shorten the engine life. Is it really safe to do?
IronZ
Go check the adds for the Saito .30 four stroke in RCM when it was first introduced.
They go on and on about how powerful it is for such a small engine and they say and I quote ," it really comes alive when you use 30% nitro fuel"
Clarence sticks with 10 to 15% so he can compare different engines using a standard base line as far as fuel goes.
It wouldn't be fair if he used 30% in a Saito and 10% in an OS then compared the two.
CK
