RCU Forums - View Single Post - Venture 60 wing
Old 03-09-2005 | 04:22 PM
JNorton's Avatar
JNorton
Default RE: Venture 60 wing
Swashbuckler,
It also makes it easy to determine if the root ribs are indeed at 90 degrees to the leading edge. I like to use building squares since they are thick and square.
I use two of them when building a tapered wing. Believe me I need all the help I can get! Check everything dry before you glue.
John
