RCU Forums - View Single Post - max effective rudder throw?
Old 03-09-2005 | 11:10 PM
MTK
Default RE: max effective rudder throw?
The Impact on 20 degrees of rudder throw flies easier knife edges, slow rolls, and the higher speed maneuvers. It needs at least 30 degrees to perform the slower maneuvers such as snaps, spins and stalls better. This model has generous lateral area around the CG which enhances rudder effectiveness, so you may want to judge accordingly, depending on your model's specifications.
MattK
ORIGINAL: falconhob
What max rudder throws are folks using for F3A? I'm just setting up my new plane, and to me it seems there would be some point at which more throw isn't doing you any good, just adding drag and creating weird coupling. 45' seems like a reasonable place to start, but is it a case of severely diminishing returns after say 30' or is it important up to 60'? Has anyone done any testing on this?
The underlying reason for the question is two fold. One, physically, I have just over 30 degrees throw as it sits, but can easily add more to the fin TE or rudder LE to get more throw. Second, I want to set the linkage for max resolution so I'd like to set the trade-off between resolution and leverage properly. Wasting resolution/leverage achieving throw that I don't need doesn't make sense.
Any advice on effective max throws welcome!
Wayne Powell
