RCU Forums - View Single Post - MT2 Tuning troubles - HELP!!!
Old 03-10-2005 | 12:01 AM
rolland
Default RE: MT2 Tuning troubles - HELP!!!
You could have had some dirt or grime in the carb or possible air leak around carb that
re-installation solved.
The factory settings on the carb is 3 turns out on the high speed needle and 1/2 turn in from flush on the low speed needle, idle gap at 1 to 1.5 mm. Try the factory settings and re-tune.
rolland
