RE: How to lower Octane??
Not strange, the carb is designed to use the crankcase pulse to pump fuel...If you want to run gas in your Saito you can use the stock carb by changing the taper on the needle...The taper needs to be a smaller angle..Best way -- buy a few new needles and start experimenting...
