Bought Plane, Built Plane, Crashed Plane...What should I do now?
Finds some experienced in person help and actually learn to fly
The area by nose cone is just broken into several foam pieces, could be repaired by glue or maybe not...
Without seeing pics I can't be sure but I'd be willing to bet it is an easy fix. Problem is I'm betting you don't have the experience necessary to accomplish this task.
I'd suggest piecing it back to with small amounts of white glue or foam safe CA. Use toothpick or pins to hold the pieces in place if you are not using CA. Good luck This is really more fun if you have help. Any chance hooking up with a club??
