RCU Forums - View Single Post - Bought Plane, Built Plane, Crashed Plane...What should I do now?
Old 03-10-2005 | 05:11 PM
Campy's Avatar
Campy
Default RE: Bought Plane, Built Plane, Crashed Plane...What should I do now?
The Easy Star http://www2.towerhobbies.com/cgi-bin...&I=LXFRU7&P=ML is one of the easiest planes to fly. It is a foamie, so any repairs you MAY need to do can be done with regular medium CA. You do not need the foam safe CA with this plane. You need to use your transmitter, receiver, battery and ESC (requires 12 amp ). Everything else, including the motor, is there.
It is larger than your average park flyer, however, this will be a big help if there is any wind. This plane, unlike many park flyers, can handle some wind.
If you decide to get this, I suggest putting a piece of packing tape on the underside of the fuselage for about the first 10 - 12 inches. It will save the fuselage from getting beat up if you happen to land on pavement or on a rock.
