RCU Forums - View Single Post - Adjustable flap and elevator
Old 03-11-2005 | 12:59 AM
2BFlying
Default RE: Adjustable flap and elevator
kd
I have excellent travel on flap and elev. and they have no resistance. Turn the plane over and they will fall that way. So if I have 1 1/2 inches of movement in up and down mode on my elevator I should have the same on the flaps,right? I made sure when I set the moving parts that I had plenty of travel. All surfaces have enough freedom to go almost vertical in up or down position without binding. My 3D plane has almost 3 inches of travel each way on the elev. and I have to gear my thinking toward C/L. It IS different from the R/C world in the control surfaces department. Have things thawed out in Minnesota yet? It's snowing now here. I'll check everything out when I get to the house and make some adjustments. I had a Buster and a Shoestring Stunter in the early 70's and they were great fliers. And about every Ringmaster made in the 60's. Oh, a quick question and you might know. Who makes the best quality kits in your opinion? This kit was so much fun I want to get started on another. Instead of spending 200-300 dollars on just the radio equipment for another R/C, i think I had rather put that money into a really good kit.
