RE: Extreme Flight 87" Yak 54 - Build & Fly
I have a rudder horn question. When I try to push the horns through the rudder they don't want to slide through. The wood in between the horns also is very fragile and a piece broke and I CA'd it back on. 1...How do I get these in? 2...They only slide so far till you get to the notched piece. Do both notched pieces go on the same side? 3. Slide in from right side, or left side? 4. It says to slide the two plates on, mark, and cut covering for them. However I have 4 plates. Are there extras in the kit, or do I need to use 4 somehow? I don't want to damage the rudder any more and I am afraid that sliding the horns in and out again will do so.
Thanks for putting up with my inexperience.
ten pillows
