RE: Extreme Flight 87" Yak 54 - Build & Fly
WaPilot, there are different shools of thought, I'll give you mine. if the cables are tite (just right) at neutral then it really doesn't matter if the one not pulling is slack when you move the ruddder. does anybody really beelieve the slack one should be pushing??? LOL At the point that you start using the rudder , only one cable is necessary. At neeutral you need them tite so there is no flutter. When your using the rudder it can't flutter because there is preasure on the rudder.
john
